BTU Question for steam boiler replacement
JohnsBoard
Member Posts: 2
<a href="file:///C:/DOCUME~1/John/LOCALS~1/Temp/msoclip1/01/clip_filelist.xml"></a>
I posted this on the wrong board so I'm posting again.
I am changing my steam
boiler from oil to gas. I currently have a HB Smith boiler with a Beckett
blower with a .85 nozzle. I looked at the Weil McLain instructions on there
website and calculated my radiators to be only 46,905.04 BTU’s. I also have a
hot water loop in the basement with a ten-foot baseboard. The plumbers I know
tell me I should use a 100,000 BTU boiler. Is that too much? I just want it to be efficient as possible.
The system I use now seems to use a lot of oil for a small house, total 1066 square
feet for the first and second floor. My roofline is steep so the second floor
has a lot of un insulated roof on the walls but the attic floor is insulated.
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
