wiring H.W. L8148E w/ Taco zone valves
S.A.
Member Posts: 2
I need to wire two taco zone valves with a Honeywell L8148E. The only diag. I can get is w/ H.W. zone valves. I have terminals marked t,tv,w,z the w,z have a jumper needed for 24v sys. I could use an external transformer , but this has become a challenge I really want to know how to wire it this way. But I don't want to toast the control, $$$.
Go from the "Z" terminal
on the relay to the thermostat then out of the thermostat to terminal # 1 on the Taco ZV. Then "TV" goes to # 2 terminal on the ZV and finally "T" goes to # 3. You should be all set.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
