Engineer
Pablo27
Member Posts: 2
<span style="font-size:12pt">I would like to know if I can get some valuable information on steam design</span>
<span style="font-size:12pt">I am working on a project to provide steam pressure to a new sterilization equipment. The steam requirements are between 65 and 75 PSI ( do you consider this high pressure or medium pressure). The boilers are located 350 feet away approximately and I have to account for losses. The steam requirements are approximately 1800 lb/hr. The steam pressure boiler discharge is approximately 75 to 80 PSI. </span>
<span style="font-size:12pt"> </span><span style="font-size:12pt">The following are other questions I have</span>
<span style="font-size:12pt"> </span><span style="font-size:12pt">Do I need to provide steam traps or can the steam pressure push any condensate</span>
<span style="font-size:12pt">What pipe size is correct, I calculated 2” schedule 40 </span>
<span style="font-size:12pt">Can the pipe be treated or it needs to be butt welded.</span>
<span style="font-size:12pt">The new steam pipe will be run in the ceiling of a occupied space.</span>
<span style="font-size:12pt"> </span><span style="font-size:12pt">As always, your feedback is most valuable, and my steam knowledge is limited. Please let me know if you can suggest a few good ways to design a good steam piping system to keep me out of trouble and do a good job. Thank you in advance and I will way for your assistance</span>
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
