To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Hydronic Toe Kick Heater Installation
DYIHelpDYIHelp Member Posts: 1
I'm remodeling my kitchen and would like to install Hydronic Toe Kick Heaters under my cabinets. My current heating source is gas forced air.
I live in a 1600 sf lofted condo with 15' ceilings and I'm always loosing heat.  The Toe Kick heaters would supplement the gfa heating system, and a new bedroom I'm making by putting up a wall.
Can water lines be install and hooked-up to my current 40 gallon hot water heater, or do I need to purchase a separate hwh system like a boiler, and if so, then my second question is:
Are very small boilers or steam systems available to attached to the toe kick heaters for condo buildings.  I'm looking at the Myson Heater, but their spec are very vague.
I will not be doing this work myself.  I'm hiring a contractor, but want to get a head's up so when I inquire, I can understand.
Thanks...
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
