Gas Boiler with Domestic Coil?
Jeremy_12
Member Posts: 8
Hi guys,
I have an apt building with NG already in the house. The house has no heating system. I want to put a boiler in for each floor.
Do they make gas boilers with domestic coils?
What brands are the best bang for the buck?
Thanks,
Jeremy
Thanks,
Jeremy
boiler w/ coil for dhw
Try looking at the Embassy Axia, or the Embassy Onyx. They are a self contained unit oem product from Italy. Pretty cool for what you need. Also venting is easy. They can produce between 3 and 5 gpm of dhw.0 -
Thanks, but I'm looking more for a standard solution in the $1k range.0 -
I doubt
you'll find something in that price range .
I know Slant Fin and Peerless make atmospheric gas boilers with coils . I don't know the specific model numbers , you'll have to go to the websites to find out more .0 -
$1000?
Well that would be a start to pay for a good professional heat/loss calc and and a well thought out design and maybe any engineering reports that may be needed. You're on the right track!0 -
I need 80' of baseboard and I need a domestic coil in a NG boiler.
$1000???
Can't even get a tankless that will put out any gpm's for that price. Even wholesale cost on a power-vent tank water heater is around 750.00
Mod/con's with dhw coils will deliver very low gpm's. In most cases they will not even meet the requirements for minimum flow set forth in our plumbing code (MN). I would avoid them at any turn considering the poor ratings given by current owners.
Peace
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional""If you don't like change, your going to like irrelevance even less"0 -
are you saying NG + tankless = no GPM? Regardless of the cost?0 -
No, not at all
A quality tankless is going to run (wholesale cost) around $1200, not including install, gas & vent.
I have switched from Rinni to Navien this last year. I really like the buffer tank and the standard PVC venting you get with the Navien.
Do your homework with the tankless units. Check the ratings for flow rates given expected delta t. The big box models most likely will not rate well.
Peace
Are YOU saying,,,
you want a NG boiler c/w domestic coil + 80` of BB for $1K??.
Might find something re-usable at the scrapyard. :-)
Good Luck!
Dave0 -
no no no, I'm looking for boiler cost of $1,000. I was just answering someone else's off topic post.0 -
I'm not looking for a tankless solution. I'm looking for a NG boiler that has a tankless coil in it for little money since it's an apartment building.0 -
Not going to find it
I think you need to consider the costs of a properly sized boiler with an additional indirect tank. This will be considerably more than $1000 but it will deliver high performance.
If you are looking for a Mod/Con boiler with a dhw coil you will likely find the prices to hover around $2000-3000.
ok, thanks guys. I'll just keep with the plan of adding the boilers/baseboard and add electric HW tanks.0 -
Why not combine all units for domestic hot water?
Unless its a metering/billing issue. I would think you could have lower operating costs using stacked gas tankless units to realize your hot water needs rather than use electrics for each unit.
The initial investment will be higher, but, operating costs should be less.
Peace
It's a metering/billing issue. Each tenant has their own gas and electric meter.0 -
Crown Cayman is........
...... a very basic, but nice, gas fired w/tankless unit. This one is 7 years old with no service issues, to date.0 -
If you can put enough baseboard in to run under 140 deg. F., you might be able to do a gas water heater w/heat exchange for each unit.
Given how inefficient a boiler with a coil in it will be for individual apartment units, this is probably a step up in efficiency and a step back in price.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
