How to unfreeze isolation flanges
D107
Member Posts: 1,849
They are slotted shutoff valves on either side of our Taco 007s; probably used due to low ceiling height instead of ball valves. usually exercise them once a year but last time they wouldn't budge. Penetrating oil?
Thanks,
David
Thanks,
David
They can be tough!
Another great reason to use anything but a set of Grundfos iso valves. I have had luck with the right sized screw driver and only when the system is hot.
Get the boiler up to temp(dial up the limit if it is a mod/con and runs at a low temp).
Good luck & peace
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional""If you don't like change, your going to like irrelevance even less"0 -
some of those
actually have a recessed hex down in that screwdriver slot. That is a better tool to use. Tap around them with two hammers. One as backup, a small ballpeen hammer to jar things loose.
P-oil may help also, if it can get to the ball.
Even the handle type iso flanges can seize after time. I have snapped the brass stem on those also, trying to free them.
Heck, even ball valves on water lines seize up.
Notice the better quality ball valves have larger diameter stems, maybe better quality brass, also. Seems like the import valves, regardless of the brand name on them, barely hold the nut to keep the handles on, anymore. The stems are so small and flimsy.
hrBob "hot rod" Rohr
Living the hydronic dream0 -
Just My Luck
Everytime I try to shut off one of those combo flange shutoffs they break or leak. Either they snap or the o ring tears. I have not tried the newer models because I been scared off. I just drop the pressure and try to hold a vacuum ..I have enough experience to know , that I dont know it all0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
