Radiant Design software?
SpeyFitter
Member Posts: 422
I'm curious what heat loss and radiant panel design software you use? Also, what seperates it from the others, in your opinion, if you feel it is amongst the best?
Class 'A' Gas Fitter - Certified Hydronic Systems Designer - Journeyman Plumber
Softheadware
I use the real stuff.
Slantfin II, thanks to Dan H. This heat loss program has never failed me in 10 years.
Radaint design, I use the old IPEX stuff. They are gone, but it also has never failed to generate a successful project.
I now need a cad type program and will go to "Siggy".0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
