MM 15E
HeatJockey
Member Posts: 37
Has anyone else experienced problems with the MM 150E probe type pump controler/LWCO? We had 2 "out of sequence" problems in the first 2 months (MM recommended cleaning the probes) then 2 cracked sections, front and rear, of a brand new cast iron boiler. The boiler is clean and never had chemicals added to the system. MM tested the control and says that it works fine, however I have photographs showing "green" lights and continuity from the LWCO contacts when there is no water in the gauge glass.
photos
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
