No more lifting!!!
lee_7
Member Posts: 458
If you do not mind, what is the weight rating on that thing, and cost. You can email cost off wll if you like. That is really nice.
I just finished! Just in time to pull a huge pump from a large condo building. Makes for easy lifting!
TimJust a guy running some pipes.0 -
I've been debating on a power tailgate for my pick up or a power two wheeler. I like the stair climber but the guy I've been paying to take out my boilers for the past 20 years has one already. I think I'm going to get the tailgate. Makes it easier to do your own deliveries.0 -
About $350, lifts 1000lb in position shown, or 500lb with arm extended. I am going to drill a hole set about 1/3 extended. I cut away a lot of one side of the base so it would sit behind the wheel well and welded & bolted it to the bed directly. I love having a good mig welder!
Hey Tim, I recognize that radiator.
Here are a couple of ways I load heavy stuff. I would not be in this business without my stair climber.
Dave StromanDave Stroman0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
