honeywell smart valve
Paul S_3
Member Posts: 1,261
does anybody have any info on the honeywell smart valve?.... the reason why im asking is that the gas valve has a 4 wire plug with a black,white,blue and orange wires. i know the black and white are a constant 24v, and the blue is another 24v circuit.. but i dont understand what the 4th wire[orange] is? it seems like when main gas is energized the smart valve sends 24v back to the circuit board? dont know why ....any explanations?
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
On a forced air furnace it tells the fan timer board that ignition was successful. The fan timer then turns on the fan after the set warm up time.0 -
Paul s the answer posted is correct
if you are interested I have for sale a complete set of manuals on Smart Valve contact me at gastc@cox.net and we will help you out.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
