blow off is very slow
Karl_10
Member Posts: 2
Blow is working very slow
the blow off is working slow0 -
slow blow
do you mean the drain from the boiler, or the low water cut off is slow.
if it is the low water cut off, then i recommend getting a pro in for service, as it may be unable to prevent your boiler from dry-firing, and destroying boiler, and building with it! if it is the boiler drain itself, then that is a problem which can wait for warmer weather, to "clean out the mud legs"; although it could save fuel to have it done sooner. --nbc0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
