Picking the right boiler
steve b_27
Member Posts: 20
Is there a rhym or reason as to picking a high effiecnt boiler.What things should I consider in this process.Are these high effient boiler more trouble than there worth service wise?
RE: service
I have been using the Triangle Tube Prestige boilers for 3 years now and have had very few issues. The Prestige boiler is probably considered a higher end boiler and seems to be built with much higher quaility components. On the other end of the spectrum, I install a much less expensive chimney vented boiler that I have had may issues. Out of the 5 last installed, 3 had gas valves that did not operate properly (a fourth seem to settle down) and now there is another recall on the vent dampers.
I have reached a point that I am now charging an additional premium on the less expensive boilers because warranty issues and defective parts run up my costs considerably.
Something to think about.
BoilerproThere was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
