mm. lwco question ?
RonWHC
Member Posts: 232
on the 67 is used for 120 volts, 24 volts, or millivolts.
lwco question?
if i replace a series 67-g mm float style lwco. with a new series 67 mm float style lwco. should be no problem? or are the contacts different with, millivolt system. tom0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
