Convector - how many BTUs ?
Michael Wildt
Member Posts: 27
Friendly bump, in case someone knows how to calculate the BTU for a convector.
Thanks,
Michael
Thanks,
Michael
Convector - How many BTUs ?
Hi,
I've downloaded Slantfin's heatloss calculator and I'm trying to estimate the house load. To do a comparison I've also measured up the total ft of baseboard and the two convectors I have in the house. Seems like the rule of thumb is ~550BTU/ft for baseboards, but what about convectors ?
I have one that is 6" x 2.5' and one that is 6" x 5'.
Appreciate any pointers on this.
Michael0 -
Do you have a height on the units and a tube count?Cost is what you spend , value is what you get.
cell # 413-841-6726
Hi Charlie,
I will open them up tonight to get the requested info. Appreciate the help.
Thanks,
Michael0 -
Hi Charlie,
I opened them up and they have the same internal hight 2" and they each have 3 tubes.
Thanks,
Michael0 -
http://www.rittling.com/literature/catalogs/cabinetconvector_0305.pdf This should give you a close idea to btu out put.Cost is what you spend , value is what you get.
cell # 413-841-6726
Thank you, Charles.
Michael0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
