Is painting new radiator neccasary?
coffeeman
Member Posts: 18
I am having a brand new Burnham slenderized radiator installed. Can I leave it the way it is (factory primed) or does it have to be painted? thanks
unpainted
would be fine.0 -
I kind of agree
the unpainted gray primer does look nice and will work fine. But you have an opportunity to make it either stand out or recede more and be easier to clean if you paint it.
Personally, I would paint it with a glossy oil-based enamel but have seen entire houses done with just the bare primed radiator and it looks great to me also.
As KJC said, you will be fine. Either way.0 -
color might matter
You might want to look at this:
http://www.heatinghelp.com/newsletter.cfm?Id=38
As Dan says, It pays to wander off the Wall.
Larry0 -
Did It
Last fall I installed a new Slenderized radiator in a bedroom of our house. So far it's still wearing primer. I'll paint it when we get around to fixing up that room. I was surprised, however, how long it outgassed when hot. That thing stunk for a month! Even the radiators I've painted at home stopped smelling like burnt paint after a few days. You'd think Burnham would use something better.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
