2 pipe steam piping
Steamhead (in transit)
Member Posts: 6,688
Is the check valve in the main return at the boiler, or does each radiator have its own? Do the radiators discharge into dry returns or wet returns? How is the air vented from this system?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
steam piping
I have a 5 story factory type building the radiators { MANY] are built up[ 1 1/2" riser and return with multiple 1 1/4" pipes off of a manifold. There is a check valve at the end in the return. It's a 2 pipe system with no vaccuum pump. Enough info? Do we replace checks with steam traps?0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
