Help in identifying a Pex brand
Colin_5
Member Posts: 1
We have a pex pipe that we can't identify the manufacturer. The pipe is labled "7/8 radiant co hydronic heat exchanger tubing". Can't find radiant co on the web.
thanks
thanks
7/8\" Tube
Is it this stuff? As far as I know, the 7/8" tubing was not designed to be used for hot water heating. I think the fittings are just barbed fittings with hose clamps. Doesn't inspire a lot of confidence. I would be wary of the connections in that system, particularly if glycol is involved.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
