connecting coall stoker in conjunction with oil burner, details
Bruce Harlor
Member Posts: 1
Where can detailed instructions be found to connected a coal burning unit with a seperate oil butning unit?
More info needed
Bruce,
That is an open question.
Is it steam, hot water, warm air?
One thing I can tell you up front is if it is not one unit LISTED for multi-fuel, then you will need 2 separate chimneys.
You can not use a fuel oil unit and a coal unit both in the same chimney.
Ed Carey
interesting question -
and combination of fuels. Depending on your jurisdiction this may or may not be feasible. That said - coal stokers and oil burners (number 2 or used oil) can be interlocked with the correct sequence of relays & temp controls to prevent both firing simultaneously. Its a popular combination for grain dryers. I would recommend you find a PLC guru and pose the question at his/her desk. Unless you are completely comfortable with commercial burner controls (and correctly trained); the complexity can be over whelming. Detailed information? That depends entirely on your selection of controls. This also brings up the issue of combustion air and chimney requirements - again some jurisdictions may allow this combination, others may not. In the combo burners I have seen - it was always the fire insurance carrier that had final word.0 -
Multi-fuel Boiler
There is a multi-fuel boiler that is made to burn coal and oil. Are you using anthracite or bituminous coal? I am very fond of coal boilers. Today many of them are automated so that you do not have to shovel coal into them. Here is a link to a multi-fuel boiler:
http://www.alternateheatingsystems.com/Multi-Fuel_boilers.htm0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
