To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
running out of ideas..
GlenGlen Member Posts: 855
is it installed so flow is correct??? if there are flow checks - trying to circ water against them makes the circ cranky. is the circ correctly sized?? too big or too small?? are all valves open? is this problem coincidental with the circ change a few months ago??
  • gwengwen Member Posts: 3
    Im new to the heating by hot water and have tried what little we know. I have a boiler that is producing hot water...the pipes are hot, heat is slowly coming from the pipes...but can't get the temp over 61 degrees even when cranking it up to 80 for a couple hours. I've tried bleeding at every spot...and got a lot of air out. The pressure is good. We aren't getting the rushing water sound that we were getting for the past few months, but not sure if that is good or bad. Don't know what else to try...any suggestions?
  • Yes
    it's time to call a pro. Click Resources above, then Find a Professional and follow the instructions.
  • Dave StromanDave Stroman Member Posts: 757
    No sound of rushing water in the pipes might mean that the pump is not working.
    Dave Stroman
    Dave Stroman
  • bill nyebill nye Member Posts: 307
    air
    It is most likely air bound. The noise in the pipes was air.
    already checked the pump....it is working. Was just replaced 2 months ago.
  • leelee Member Posts: 458
    where are you located?
  • kpckpc Member Posts: 11
    it may work....
    just that there is air in the piping. Are the pipes warm/hot 20' from the boiler?
  • JimJim Member Posts: 244
    no/low heat
    As far as the pump goes, I always ALWAYS go by the idea," just because its new, doesn't mean its good." I will guess here that the pump is a compact circulator. Use a stethescope or screwdriver method to determine if it is humming or actually spining. In the threads posted so far I do not see the boiler pressure indicated. Do not go by the boiler gauge but rather a gauge made to screw onto a boiler drain. Its a standard tool I keep on the truck to make sure there is ample pressure in the system. keep us posted
  • jpjp Member Posts: 1,935
    pump working?
    the pump can be working(buzzing, humming) but still not being actually pumping water. air up higher in the line can keep it from moving water.
    rochester, ny
  • fattyfatty Member Posts: 54
    sounds like the pump - if not a physical blockage... just my opinion
  • Jack P.Jack P. Member Posts: 38
    What temperature is the aquastat set at?
  • Is the...
    Pump motor excessively hot? If you don't like keeping your hand on it very long chances are it's airbound. Motor should feel warm but not hot.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
