Pressure Entalpy in Plainview
Eugene Silberstein 3
Member Posts: 1,380
For all of you Long Island folks, here is a rundown of what we have in store for the August 10th Pressure Enthalpy without Tears seminar.
Review of the basic vapor compression refrigeration cycle.
Review of superheat and related calculations.
Review of subcooling and related calculations.
Use of the pressure/temperature chart.
Importance of flash gas.
Relationship between flash gas and subcooling.
Introdcution to the Pressure Enthapy diagram.
Plotting an air conditioning system on the PE diagram.
Using the PE chart as a troubleshooting tool.
Using the PE chart as a system start-up aid.
Using the PE chart to determine system cpacity.
Using the PE chart to determine system efficiency.
PLUS.... You get breakfast, lunch and some quality time with some quality people (I am referring to the other HVAC experts in the NY area who have already signed up)
Hope to see you all in Boston in a couple of short weeks!
Time is running out
Time is running out for the Long Island shindig.
Take a break from the summer heat... if only for a day... Don't worry, the work will still be there when you get back!0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
