Radiant Heat Help Needed in SC
Paul McKibben
Member Posts: 2
I'm building a house in Beaufort, SC, and want radiant heat. I understand "nobody does this" in the area because of the warm climate. I also understand it won't be as economical to install as a conventional furnace (and I'll have to have the AC system anyway). Nevertheless ...
My architect can't locate a local engineer (say in the Charleston/Beaufort/Savannah general area) to do the design. We'd like an engineer who is familiar with local practices and contractors, if any.
Can anyone point me in the right direction?
Paul McKibben
Norcross, GA (soon to be Beaufort, SC)
Paul McKibben
Paul,
There are people that will design the system for you virtually everywhere, but an installer may be a bit hard to find.
There's a gent named David Broome in SC, but he's in Sececa, SC, in the northwest corner of the state. I'm located in Woodstock, GA, not too far from you now.
Assuming that you've put in an accurate email address and it's good, I'll make a couple of calls.
Radiant heat isn't cheap to install, but the comfort level is much greater than what FA can provide.
Jeff - Thanks for the quick response. My email is accurate (hope it doesn't garner a bunch of spam!) and I look forward to anything you can provide.
Paul0 -
just understand
That any name I may send to you is not guaranteed to a be the 'right' person for you.
Jeff
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
