CRO valves
don_185
Member Posts: 312
www.sporland.com has some great literature on how to adjust
a cro valve.
a cro valve.
CRO VALVES
was wondering how you set a cro valve? i have been taught diffrent ways seems no one i know is for sure. do you do it by compressor amp draw?is the only purpose to prevent liquid flooding back on start up?? any help is appreciated!!0 -
You are correct
You should examine the compressor nameplate and determine the maximum apmerage at which the compressor should safely operate.
Then, with the compressor operating, you can adjust the valve accordingly.
Best of luck.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 27 Recall Announcements
