condensing boiler
rich_42
Member Posts: 9
condensing boilers viesmann vs. buderus vs. tringle tube & why is one better than the other. viesmann has abuilt in mixing control.valve
Which Viessmann?
The Vitodens does not have an internal mixing valve but does have an internal diverting valve to heat domestic hot water, just to be clear. EDIT: The Vitodens and other models have add-on setups external to the boilers though, with control outputs as Andrew noted. It is just not a "given".
Given a choice and based on shear quality, the Vitodens 200 would get the nod, hands down as my #1 choice. Below that and subject to more field experience, the circulator-less Vitodens 100. My third choice would be the Triangle Tube Prestige.
What all three have in common is a stainless steel heat exchanger which I know to be more durable and more tolerant of the pH level encountered. Not that aluminum (the Buderus GB-142) cannot deal with it. Just that the material in and of itself is more tolerant.
The Viessmann stainless is type 316 Ti (titanium stablilized). It is an incredible material and I believe is proprietary to Viessmann. Otherwise 316L is pretty common; "L" stands for "low carbon", BTW.
Brad0 -
Ranking
The Vitodens does have internal control for an add-on motorized mixing valve on Heating Circuit B.
Of the 3 mentioned, I would rank them best to less best: Vitodens, Prestige, GB-142. Which is appropriate for your application and budget is a different question.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
