Burnham Slenderized Radiator
Does any one have any info on installation procedures and rough-in specs ? I've tried all my sources and no luck. Just too many varibles I think.
TheFuture
  • Rough-in data
    You are correct in your statement regarding too many variables. You can view the dimensional data for the radiators from our website at the links below, but installation procedures and rough-in data are totally dependant upon how the radiator is going to be used and piped. They can be one or two pipe steam as well as hot water. We can't neccssarily publish rough-in data as this will vary based on whether it is steel pipe or copper and various valve and union elbow products vary in their dimensions. If you have the valves and union elbows in hand then you can determine this along with the radiator dimensional data. Hope this helps.
    http://www.burnham.com/lit/Baseray.pdf
    http://www.burnham.com/radiator/58210.cfm
    Glenn Stanton
    Manager of Training
    Burnham Hydronics
