Aerocowl vent vs Fields for Buderus DV?
Jed_2
Member Posts: 781
"I've used both on Buderus installs and was wondering which might work better <around windows> w/out introducing too much odor in the summer? Thx"
Hopefully you are maintaining at least the minimum, preferably more, clearance to these windows. It gets tough sometimes to maintain these clearances, but they are crucial. The Aerocowl will get the exhaust gases out further from the exterior wall, and recirculation should not be a problem. But, watch the window clearance.
Jed
Jed
Jed
Jed
Anyone have any opinions on using the Aerocowl w/ separate fresh air intake vs the Fields concentric type unit? I've used both on Buderus installs and was wondering which might work better around windows w/out introducing too much odor in the summer? Thx0 -
Field vs areocowl
I've used only the areocowl. You may have some issues with cold combustion air. The fields "had" issues with cross contamination they may have corrected that. The more I look at it maybe powerventing is the better option.0 -
I agree w/ the Capt.
I have used both...the last a Fields. I switched due to the cold air intake not allowing good atomization at the burner...they have improved it. MAke sure it is off the ground plenty....If you can use a chimney. kpc
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
