Radiator in basement/ heat from condensate return.
Unknown
Member
It was the Webster system in the building just right of the BIG building, the one I took the tank out and put in a hartford loop and a main vent.
Getting the water to go the right way in the high return (downhill) made a world of quiet in that building.
http://www.colby-sawyer.edu/
Noel
Noel
Steam radiator in basement/piped on dry return
Is it feasible or permissable to pipe a cast iron radiator in the upper left tapping off a dry return line in a basement(above boiler water level), than exit the radiator on the lower tapping (now a wet return),than pipe back to the Hartford loop and gain heat from the dry return steam/condensate and the hot wet-return water flowing through the radiator. Is this possible to attain?0 -
maybe
You don't want it within the "A" or "B" dimension in the piping, because it will fill with water as pressure climbs.
Today's boilers can't afford to lose a radiator-ful of water and still make steam.
They used to put them flat on the ceiling on steam systems, pretty often.
Noel0 -
I've seen it done
It works best if you have all the condensate from the building going thru the rad.
P.S. Noel- I remember that rad- was that on one of the Milvacos?0 -
radiator below steam main
installed one exactly as you describe in 1972 . works well when heat is on. but since thermostat is on upper floors baseboard loop is the best solution if real comfort is desired. separate zone0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
