To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
dual temperature systems
BILLBILL Member Posts: 2
WHAT IS THE PURPOSE OF HEAT PLATE EXCHANGERS IN A DUAL TEMPERATURE SYSTEM.
  • BILLBILL Member Posts: 2
    DUAL TEMP SYSTEMS
    THE DUAL TEMPERATUR SYSTEM IS A HOTWATER SYSTEM ,WITH TO HEAT PLATE EXCHANGERS DIVIDING THE CHILL WATER SYSTEM TO THE HOTWATER SYSTEM. WHAT IS THE PURPOSE OF THE PLATE EXCHANGERS.6 INCH CHILL WATER PIPING, 8 INCH HOT WATER MAIN.
  • Brad WhiteBrad White Member Posts: 2,393
    A couple of possibilities
    The plate exchanger could be separating the two systems because of the source pressure (such as in a high-rise) or because the hot or chilled water has different solutions (glycol or no glycol, chemical treatment, etc.
    It could also be that the PHE is used for free cooling water-side economizer using condenser water for example.
    Without a diagram or more information it is just a guess.
    Traditionally, 2-pipe systems have 3-way diverting valves for change-over. Again, a diagram may help to get you a better answer.
    "If you do not know the answer, say, "I do not know the answer", and you will be right!"
    -Ernie White, my Dad
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
