Cast Iron baseboard Rads push nipple removal
Dan C.
Member Posts: 248
Doesn't take long . Just heat up the nipple and pull it out. I think thats the only way.
Cast Iron Baseboard Rad push nipple removal
Does anyone know of a tool or faster way of removing the push nipples from the cast rads besides heating up the rad with a torch and grabbing with a vise grips. I'm trying to refit some rads together but the existing rads have either one or two nipples installed in same spot as the rads I'm fitting in.
I was hopping not to trash them or replacing them.
Thanks0 -
push nipple removal
if you need to do a lot of them than go to an autobody parts store and purchase a "slide hammer " you can make a hook for the end and out pops the nipple
mike
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
