Vision I & II
Bill Clark
Member Posts: 12
Can you point to where I can find I&O documentation for Vision I & II? (I need this to evaluate the product before attending a class, should that seem be worthwhile.)
Bill Clark 303 449 4878
Vision info
Bill, If you go to the Heat Transfer website, you will find everything you need regarding Vision I & II
http://www.htproducts.com/index.html0 -
more detail needed
Bruce, I see the Vision glossies on the HTP website but not detailed I&O manuals (or equiv). Do you have a URL?
My solar/boiler retrofit entails plenty of tackiness. I really need to see the definition of all the 'knobs' on that control. Eg, how will it handle a HX interposed between boiler and heating load (issues are servo stability and condensing performance); does it seem that the mixing valve drives can be coupled to existing valves; can the modulating zone controls be made to work with another heat source (solar storage)?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
