News from B&G
DanHolohan
Member, Moderator, Administrator Posts: 16,526
Morton Grove, Ill., June 29, 2005 - A new bulletin is available for Bell & Gossett's Valve Installation Kits, which help improve HVAC system operating performance, and save time for engineers and installers in the field.
The bulletin (A-608) details the features of Bell & Gossett's (16) standard Valve Kits, which provide hundreds of installation combinations and options for flexible braided metal hoses and pipe run out sizes from 1/2" to 2". The kits also allow for a variety of packaging and tagging options. Valves and accessories highlighted in the literature include:
Model AC Circuit Sentry T Automatic Flow Limiting, Commissioning and Shut Off Valve
Model UBY Combination Wye Strainer and Shut Off Valve
Model UVB Ball Shut Off Valve
Model MC Circuit Setter Plus® Calibrated Balance, Commissioning and Shut Off Valve
Model UA Union Accessory
The bulletin also includes a diagram, which illustrates system functionality and integrated ports for accessory devices such as pressure and temperature measurement ports, air vents, or drain valves. The diagram outlines:
Coil Terminal Connection Size
3-Way Temperature Control Valve Connection Size
Calibrated Balance
Union Accessory with One and Two Pressure / Temperature Ports
Bell & Gossett
Bell & Gossett, a unit of ITT Industries, is a leading manufacturer of centrifugal pumps, circulators, hydronic specialties, heat exchangers, and packaged systems for variable and constant speed pumping, heat transfer and pressure boosting. For more information contact Bell & Gossett: 8200 N. Austin Avenue, Morton Grove, IL 60053; phone 847/966-3700; fax 847/966-9052; or visit www.bellgossett.com.
Calibrated Balance
Bell & Gossett
Retired and loving it.
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
